A/C and fan problems
Old Mar 9, 2022 | 12:51 AM
nckarm4's Avatar
2013 G63
Hi all,
I started having some issues 2 days ago in my 2013 G63. Radiator fan goes on high about 30 seconds/1 min after turning the car on and just stays on high. Mind you its about 60 degrees outside. Also A/C does not blow cold anymore.
Everything was working fine last week when I dropped the car off to have minor body work done. Two days ago, I received the car back and the issue was there
Heres what Ive checked:
Coolant level is ok
A/C pressure sensor is replaced
Battery was replaced
All relays in the passenger front fuse box replaced
All fuses seem to be working properly
Temp gage shows about 90/95 degrees constantly, it does not increase
Any help is appreciated,
TIA
Old Mar 9, 2022 | 06:20 AM
streborx's Avatar
Top Answer: 1
G550
Originally Posted by nckarm4
Hi all,
Coolant level is ok
TIA
Did you check the A/C refrigerant?
Old Mar 9, 2022 | 09:24 AM
nckarm4's Avatar
2013 G63
yep Freon all good
Old Mar 10, 2022 | 10:15 AM
knowbenz's Avatar
Benz
You need to hook a scanner up and find out what is triggering the fan to come on. Fan needs speed signal from M.E. or it will default to full hi but need a scope to properly check what M.E. is requesting.
Old Mar 13, 2022 | 10:04 AM
WillinMA's Avatar
2020 G550
Hi all,
Coolant level is ok
TIA
The shop put in too much freon after they replaced the sensor. You can buy the pressure guages and check the low and high side of the AC system and my bet its over pressurized with too much freon. The symptoms are that it actually doesn't blow cold air and the fan is on high so it sounds like the car is about the take off like a plane!!! Once they let some out it will go back to normal!!!
Old May 31, 2022 | 01:06 PM
nckarm4's Avatar
2013 G63
thanks for everyones reply. for anyone wondering, this ended up being a burned fuse in the fuse box in the engine bay passenger side. The fuse box does not look like a fuse box at all and has very strange fuses inside of it. one of those fuses were burnt. its not possible to find individual fuse so had to replace the whole box. again very strange
