Correct Wheels for 2017 G63 with 305-40-r22 Tires ?
Old Jan 20, 2026 | 02:46 AM
djstiky's Avatar
2017 G63 AMG
Hey everyone,
First of all, happy to now be part of this community and a new proud owner of a 2017 G63 AMG! I currently have a set of almost new Nitto NT420V 305-40-r22 tires, and now looking at getting custom wheels made.
Would 22x10J and ET 36 offset wheels work for me with those tires? I just don’t want them sticking out of the wheel arches, also don’t want any rubbing issues. Would they sit flush (or almost)?
Thanks!
Old Jan 20, 2026 | 04:14 PM
djstiky's Avatar
2017 G63 AMG
I like how these look, however that user did not mention the offset on his post.
Old Jan 20, 2026 | 06:49 PM
Gazam's Avatar
Originally Posted by djstiky
Hey everyone,
Thanks!
22x10J ET36 with a 305 tire will be very aggressive. They'll stick out past the fenders, maybe 1-1.5 inches. You'll likely get rubbing at full lock. For a more flush fit without rubbing, you'd want an offset closer to ET45 or higher on that width.
Old Jan 20, 2026 | 07:58 PM
djstiky's Avatar
2017 G63 AMG
Thanks for your input Gazam. I'm so confused as I'm getting so much contradicting info. Here's what CoPilot says:
For your 2017 G63 AMG on 10Jx22 with 305/40R22, “flush” with the arches usually means a bit more poke than the conservative ET40 you were considering.
Rough guide for the front (where it matters most visually):
• ET40: Slightly tucked, about 16 mm more poke than stock → clean, but not fully flush
• ET36: About 20 mm more poke than stock → visibly wider, close to flush
• ET32: About 24 mm more poke than stock → very flush/aggressive, near the edge of the arch
So, if your goal is:
• Clean, almost flush but safe: go ET36–38
• True flush / aggressive look: around ET32–34
Personally, for a G63 with 305s, I’d aim ET36—it reads flush to the eye without looking like it’s trying too hard or risking rubbing under compression.
I hope someone like this person, who's actually tried them, see's my post and provides tried and tested info.
Old Jan 20, 2026 | 11:49 PM
G63 Milk Truck's Avatar
Here’s what stock ‘25 on 295 F1s look on a 2017; no spacers, no rub on full lock and I personally think these are the best looking forged wheels for the G.
I would of went 305s however the tires were near new condition so I’ll hold off until these wear out.
Old Jan 25, 2026 | 07:37 PM
hard top's Avatar
2012 Land Rover LR4 5.0L V8 LUX HD
Yeah, those polished aluminum rims are sharp asf and the best fit. An angle pic doesn't do them justice.
