2020 g63 offroad tire pressure
Are they stock tires? If so, I'd stay fairly close to the suggested pressure on the door jamb. I'd for sure stay above 20psi. If you have larger tires, you might be able to air down a touch, but unless you have much larger tires than stock you run the risk of pinch flats and/or the tire peeling off the wheel. The traction gained by going lower is not worth the risk of flat tires. There's just not enough sidewall to go very low.
2021 G550, BMW X5M, 2020 Toyota Supra LE
Agreed with above post, these factory tires are too slim to air down considering the risks.
I have off-roaded quite a bit with 2 previous Land Cruisers. When hitting the serious trails I would air down to 12-13psi. However, with the big rims and narrow sidewalls on the G, I wouldn’t airdown, unless I was stuck.
You could lower some in hopes of avoiding a flat, but I would rather have a flat tire, than air down too much and have a damaged rim.
