G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Paint meter readings?
Old Aug 14, 2023 | 02:35 PM
LYSHOLM's Avatar
e55k
Hello All,
I just took some paint meter readings on a 2021 G550 with 9k miles that we are considering purchasing. All panels were 4-4.75 mills, but the hood was 6.25-7.75 mills. There is no evidence of new clear coat, overspray or sanding, etc. Are these cars painted by hand? Would this be an acceptable variance or has this G550 had paint work?
Thanks.
D
Old Aug 14, 2023 | 02:43 PM
blacklightus's Avatar
CLS63 AMG
Good to know that the hood is thicker. It has the largest surface area outside of the roof. Did you happen to check the roof? I'm curious to know if the mil thickness is similar to the hood.
Old Aug 14, 2023 | 03:00 PM
LYSHOLM's Avatar
e55k
The roof was the same as the other panels. Only the hood showed a variance.
Old Aug 14, 2023 | 05:30 PM
Hodog16's Avatar
2026 G63
I believe they are painted by hand or at least part of the vehicles are based on the factory videos I watched on youtube.
Old Jan 12, 2024 | 08:17 PM
sbasham's Avatar
2014 GL450, 2012 Land Rover LR4, 2003 Mitsubishi Montero
I get similar readings on my 2021 g63 as you do Lysholm.
