G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
New wheel recommendations!
Old Jan 14, 2024 | 02:15 PM
dcarrer0's Avatar
2021 G63; 2018 Aston Martin DB11
I have 21" wheels on 63 but I would like A/T tires. You can't find any for 21". I wouldn't mind 20 or 22. Any recommendations? I really like the ones I have now. Thank you all!
Old Jan 14, 2024 | 04:55 PM
Hodog16's Avatar
2026 G63
OEM trail package looks very similar and is 20". That may be the easiest route to go.
There are good A/T options in both sizes so just depends on your preference. The OEM trail package tires are A/T (but not as hardcore as others) and of course OEM-sized approved, but the 22" A/T's are all different than OEM 22" sizes. I'm not sure if there are other options in the OEM 20" tire size.
Old Jan 15, 2024 | 08:23 AM
streborx's Avatar
Top Answer: 1
G550
20" has a much better selection of brands and tire styles, not to mention lower prices and availability. And if your intended use for A/T's is off road, the 20" gives you an extra inch of sidewall cushion.
Old Jan 16, 2024 | 03:17 AM
sbasham's Avatar
2014 GL450, 2012 Land Rover LR4, 2003 Mitsubishi Montero
Is there a good way to know which 20" wheels will fit over the AMG calipers?
Old Jan 16, 2024 | 09:11 AM
The Butcher's Avatar
G63, G65
@dcarrer0 I have a set of HRE wheels with Terra Grappler AT tires that I'd be willing to sell. Tires are 305/45R22. Probably have about 4,500 miles on them. Look new, and rims are clean, no scratches. $7,500 shipped to you in Kentucky.
streborx's Avatar
Top Answer: 1
G550
The easiest way is to have your wheel/tire dealer check. If you're buying wheels online, call and ask about the wheel's inside diameter. Nominally, a 20" wheel will have 1/2" less clearance than your 21". If you can slide a 3/4" thick gauge between your caliper and 21" wheel, you should be fine. I ordered my G with 20" and it's not AMG caliper equipped, so I can't verify for you. But my BMW X7 came with 22" wheels and massive M-Sport calipers, yet a set of 20" wheels cleared its calipers with 1/2".
Old Jan 16, 2024 | 03:06 PM
JW001's Avatar
G63
The stock 21" MICHELIN LATITUDE CROSS tires that came with the MY21 G63 is a pretty good A/S tire.
