New Addition to the Garage
Just had one question and would be glad if someone could help me out.
On the dashboard at the bottom where it says what gear you are in etc- when you are driving it says "D" but next to that it says "H". Is that normal? Im just worried as the salesman had told me don't mess about with the suspension settings and I am worried that I am in the wrong suspension setting?
Pics attached (btw im not the guy in the pic thats the salesman)
H is for High Range which is the normal setting. L is for Low range, which is for extreme off-roading!
Enjoy!You can only change from H to L when at a standstill and in Neutral. Once you do the transfer case makes the gearing much shorter and more powerful which is basically good for serious off-roading!
