RENNtech hand held tuner ECU upgrade G63 Gains: +88 HP & +65 LB-FT
Hello all,
Below is information on the G63 RENNtech hand held tuner ECU upgrade. By far and away the most easy way to tune your ECU or change it back at anytime by far and away the ONLY company I would trust in ECU tuning for Mercedes. Gains: +88 HP & +65 LB-FT Up to 731 HP / 786 LB-FT These are available for immediate shipment once we receive your VIN . Please contact me for a shipping promotion we are offering at either info@etkms.com or call 1-866-950-7779 Orders can be placed via the website here https://www.euroteckracing.com/produ...er-ecu-upgradeor by phone. RENNtech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal! Our proprietary tuning module stores both the RENNtech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RENNtech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980s! Our experience, countless hours of in-house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. RENNtech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicle's entire power band. By modifying ignition timing and throttle mapping, optimizing air-to-fuel ratios, increasing the engine's rev limiter and modifying boost mapping for turbo-charged vehicles, RENNtech performance software unleashes the true potential of your Mercedes. With the proprietary RENNtech ECU Tuning the W463 - G63 AMG gains up to +88 HP and +65 LB-FT, based on power numbers measured by RENNtech. Please note that the Mercedes M177 engine performance when measured, obtains higher numbers than rated from factory. The maximum power number reached with the RENNtech ECU Upgrade for the G63 AMG is 731 HP and 786 LB-FT. Notes:
G63 AMG (MY2019+ | W463 | M177 | 4.0L V8 BiTurbo) Modified Performance (at crank):
https://cimg0.ibsrv.net/gimg/www.mbw...1dcac322ce.jpg https://cimg4.ibsrv.net/gimg/www.mbw...4b87f0905d.jpg https://cimg5.ibsrv.net/gimg/www.mbw...4a19477bd0.jpg |
does it remove also the speed limit?
Originally Posted by manuel009
(Post 7759010)
numbers are confusing. Chart shows 9HP gain and 60l oss in TQ. Product Claims of 731 HP and 786 LB-FT???
Originally Posted by horse86
(Post 7760356)
The chart numbers are TO THE WHEELS as it says on it. The numbers you are going off of are to crank so you need to add 16% to the chart numbers. 731HP to the crank with 16% drivetrain loss = 614HP 786 TQ to the crank with 16% drivetrain loss = 660tq However, there is a mix up on the chart, the light blue line is the stock TQ numbers, and the dark blue line is the Renntech TQ numbers, as we can see, they have the numbers for the TQ backwards as the dark blue line is clearly making more power than the light blue line. |
