General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Fuel Tank Fill Levels
Old May 18, 2006 | 11:16 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Question Fuel Tank Fill Levels
Hello Friends,
I have been told that to have the various fuel tank levels at, or below, 1/4 tank is hard on the fuel pump (not necessarily in our fine vehicles, but others). Is this true of the M-Bs also?
I know about the theory concerning water condensation in the tanks due to low levels, but I would welcome any comments on this issue as well.
Thanks in advance,
Musikmann
Old May 26, 2006 | 05:41 PM
Petmerctech's Avatar
Yes, running your tank very low is hard on the fuel pump but it's not really condensation that is the issue but it's that the fuel pump relys on the gas to cool it. The fuel pump needs to be submerged in the gasoline to keep it cool. The more time it spends unsubmerged, the hotter it runs which leads to a shorter service life.
Old May 26, 2006 | 05:47 PM
JDM's Avatar
JDM
2011 C300
..I have heard this too, especially in the summer, but I've also heard than debris in the bottom of the tank is another reason, true?
Old May 26, 2006 | 06:28 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Well, the tank pickup is always on the bottom of the tank no matter how much fuel is present. They have a screen on them to keep large debris form getting into and fouling the pump. Small particulate matter is then trapped by the filter before entering the rest of the fuel system. The cooling issue mentioned above is the primary issue.
Old May 27, 2006 | 04:46 PM
Jayhawk's Avatar
S500/W220/2000
So exactly how low should I go so as not to hurt the pump? Above 1/8, 1/4, 1/3 of a tank? Any variables that affect safe minimums?
Old Jun 10, 2006 | 07:03 PM
Musikmann's Avatar
Lightbulb How low?
Why go low at all? Unless you have to drive several hundred miles without passing a gas station, refill it at 1/2 tank. Just a thought...
Old Jun 10, 2006 | 07:28 PM
Jayhawk's Avatar
S500/W220/2000
Good thought! We should not think in terms of "How low can you go?"
Old Jun 10, 2006 | 10:42 PM
NZ_Benz's Avatar
1993 300SEL/S320
I always keep mine above half way.
Old Jun 11, 2006 | 08:20 AM
I would say 1/4 of a tank would be a reasonable limit to refuel.
Old Jun 11, 2006 | 08:59 PM
Musikmann's Avatar
Smile Petmerctech
Since you appear to be an actual MB tech, I will take your opinion as the gospel!
Thanks my friend
