Esp Abs malfunction and weird noises
mercedes e240 2005
Heyyy!! Im haider from pakistan. I have a Mercedes e240 2005 model 191000 kms driven. Yesterday my tire got bursted and changed it to stepny after that the esp and abs defective malfunction came into the cluster. And today my car got heated up and coolant pipe got bursted. Well i got it fixed but now i hear sound from the esp and abs portion or thing at the front what is the issue? Is it beacuse the tire doesn't match the other three?
If your tires are not all the same size (or the same side to side on a staggered wheel setup) you can get traction control issues and abs will try to activate from the difference in wheel speeds. If your tire was damaged and came apart while driving, you could have also damaged some of the wiring between the abs sensor and the vehicle.
The sounds from the ABS unit are normal because the vehicle is seeing different wheel speeds because of different tire sizes or possible damaged wiring. As for the coolant pipe, that is not related to your traction control/ esp issue.
