Rear Entertainment System Question!
06 CLS55, 07 GL450, 07 GMC Yukon, 06 Pontiac Vibe
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
The kids want to play PS2 on the RES. I cannot get the 3 plugs (red, white, & yellow) to fit securely into either of the aux connectors. Do I need some extenstions or what am I missing?
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
GL 450
We have had ours hooked up with no problem but I believe another poster had a similar problem a few months back using the jacks. Are yours loose or too big?
They are loose. But I just thought of something. There is a plastic covering over the face of the unit that I thought was suppose to stay there. It could be preventing the plugs from going all of the way in. Did you remove the plastic covering that came with the unit.?
Depends where I'm going.
I have a PS2 setup in my GL and I don't recall having a problem with the hookups. Mine is the newer smaller chassis PS2 if that makes any difference.
