Homelink antenna
Old May 13, 2007 | 08:06 PM
293's Avatar
293
GL 450
Homelink antenna
Does anyone know where the Homelink antenna is on the GL?
Is it in the rearview mirror or is it in the rear glass or else where?
Thanks in advance.
Old May 13, 2007 | 08:12 PM
AutoSaurus's Avatar
1997 E320 Sedan
Thanks in advance.
My guess is the rearview mirror. I just know is stinks as well as the ML but not quite as bad.
Having problems programming? Roll down the windows and get under the opener. That is the only way I've had success programming mine.
Old May 14, 2007 | 12:14 AM
labjr1's Avatar
2006 S430, 2007 GL450, 2007 S550
Homelink works well for me.
I disagree, I had no problem programming mine and it works from 1/2 block away. It has as much range as my previous vehicle and more range than my wife's Lexus.
Old May 14, 2007 | 09:15 AM
AutoSaurus's Avatar
1997 E320 Sedan
My ML works roughly 150 feet away. The GL? Maybe 30 feet, if that much. And I have to be facing the garage and not turning into the driveway. I live with it but its another annoyance.
Old May 14, 2007 | 12:17 PM
abcdef's Avatar
2022 GLE 350; 2016 BMW 428i gran coupe; 2014 Audi Q5 tdi
Do you have 3 zone climate control? I believe this option with its window film tint reduces the transmission range of the home link signal.
I have 3 zone climate control option and was able to program the door opener without a problem. I do have to get closer to the door with my GL to get it to open than my other vehicles (BMW, etc.) but it is not a big issue for me.
Old May 14, 2007 | 12:19 PM
AutoSaurus's Avatar
1997 E320 Sedan
I have the 3-Zone on my GL.
Old May 14, 2007 | 05:11 PM
carpersn's Avatar
2019 Volvo XC90 Magic/Amber, '95 E320 Cabriolet Midnight,'14 GL350 Lunar/Almond was '07 GL320CDI
I also have the 3-zone and had no problems...i think it may have something to do with the receiver on the garage door unit itself.
Old May 14, 2007 | 05:20 PM
AutoSaurus's Avatar
1997 E320 Sedan
Nope. Works fine from a distance on the ML still. I used a handheld for a few days and it worked fine too. My afterschool sitter has one and she has no problems with hers either.
Old May 14, 2007 | 06:33 PM
mbbodytech's Avatar
04 C320 Coupe MT
It is located in the mirror - same as the ML.
Old May 15, 2007 | 12:53 PM
293's Avatar
293
GL 450
For the people who do not have problems with Homelink what brand or garage door opener do you have and where is the recevier actually located i.e. up high by the motor or lower by the wall button that you push to open the garage door from the inside?
