Would the GL550 wheels look awkward on the GL450?
This may be a stupid question, but would the 2010 GL550 21" wheels look awkward on a 2010 GL450? The reason I ask is because I believe the GL550 has different fenders. I am wondering if the GL550 wheels would stick out too far on the GL450.
And not sure if this makes a difference or not, but my GL450 will have running boards.
Thanks for any help..
21 on a GL450
It will not.. i currently run 22's on my 450 and looks great with running boards as well. Adding the fenders from the 550 will run you about 1300-2000 painted and installed by a professional body shop.
It will unless you add fenders b/c the rim offsets are different = What you said about the rim/tire sticking out too far. You could probably find similar-looking style that would bolt on without the issues by looking around.
08 GL450
GL 550 wheels have 37 mm offset, GL 450/320 wheels have approx 53 mm offset whether 18 or 19 in diameter, which means the CENTER LINE of the GL 550 wheel/tire " sticks out " 16mm ( 2/3 in ) farther . Has nothing to do with diameter, as a set of 26 inch dubs with 53 offset will
"fit " narrow fendered GL 450 better than 19 inch aftermarket wheel with 37 mm offset , assuming overall rolling diameter is maintained stock via tire width choosing, forgetting practicality for the moment .
So as stated above , w/o the GL 550's fender flares , your GL 450 will look kinda like a low rider and you might sand away your side paint with all the road grit thrown up by those big tires sticking out, not to mention the rooster tail of blinding water you throw up behind you in a rainstorm- the latter is very carefully monitored in Europe and leads to manufacturer fines . That's why OEM cars, even sports cars , cannot push tires aggressively to the fender wheel opening lip edge , so the reason for aftermarket wheel spacer kits .
Someone posted a parking lot picture here last year of a 450 w/550 wheels and it looked fine. 16mm on the outside offset is nothing with the clearance on a GL, and the tires were not sticking out past the fenders.
I have a 2008 320 CDI with the new 2010 AMG 21".
It looks fantastic and there is not issue with the rain (and we had a lot in Atlanta!)
I will post pictures later.
Help! What is the correct tire pressure?
GL450, S550 Carlsson, Dodge Ram Laramie
Can someone tell me where i can get the best price on GL550 wheels for my GL450? I think they look better than the ones i got on my 2010 GL 450. thank you
alvillar2000 the 21" AMG rim and tires look great on your GL320. Your photos were just what I needed to relieve me of any worries that I had concerning the GL550 21" AMG rims. I can now look with confidence to purchas the 21" AMG rims for my GL450. Thanks for the photos!!
2011 s65 2010 gl550
wheels
GL550 wheels
I just bought the 2011 wheels/tires for my GL550 and have the original ones. They are pristine/flawless with only one having 1/2 inch very shallow scratch; that is it. 2 tires are 50% tread and 2 tires are 30% tread. I can send you pictures if interested.
GL 550 wheels
I have the 21 inch AMG wheels like new but they are the original ones that came on my 2008 GL. Just got the 2011 rims for it but have to say the old ones are just as sharp
