Measuring oil level
Old Jul 18, 2010 | 02:47 PM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
Measuring oil level
Other than the dip stick, is there any way to check the oil level in a GL? In my C class and old ML, this could be done from the instrument cluster.
I did a quick search on this forum and did not find anything about how to do this, only someone saying that from the Min on the dipstick to the max is approx 2 quarts.
I did an oil change yeaterday using the dipstick suction method, and put in 9.5 quarts of M1 0w40. The oil registers halfway between the min and max on the dipstick after a 15 min drive and 3 hour cool down.
I was hoping for something like my C55 has which tells me there is 8.0L thru the dash menu.
Old Jul 19, 2010 | 11:17 AM
atwal's Avatar
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
I use the same method as you do for oil change. I have noticed that the oil quantity recommended in the owner's manual is not enough. I have been filling with 10 quarts. At the same time you don't want to overfill too. If the oil level reads between min and max then it should be appropriate. You will get a warning light at instrument panel when the oil is low.
Old Jul 21, 2010 | 01:16 PM
Popo's Avatar
Thanks atwal - I will monitor using the dip stick :-) Good to know thiere is an "idiot light" if it gets too low also.
Old Jul 22, 2010 | 03:01 PM
lkchris's Avatar
'10 CL550, '12 GL550
No, unfortunately the electronic monitoring system is removed ... thanks to the neanderthals that can't live without a dipstick. I read they still haven't convinced BMW, but Mercedes has capitulated.
There WILL be an electronic warning if something is wrong with the level, i.e. too high or too low. (as noted)
