Brake Pads (GL)
Old Aug 13, 2010 | 07:32 PM
Greul's Avatar
'08 GL 320 CDI (scheduled delivery 3/20/08)
Brake Pads (GL)
Does anyone have do-it-yourself suggestions or tips for replacing brake pads? If so, would be much obliged.
Old Aug 14, 2010 | 09:02 AM
atwal's Avatar
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
https://mbworld.org/forums/gl-class-...rake-pads.html
Read this link above. It provides the tools and where to mount the jack stand. You will need to buy two cans of brake cleaner spray, front and rear new set of brake pads, one pad sensor for front and one pad sesnor for rear, MB brake paste, and MB dot 4+ brake fluid. Rest is easy if you have done brakes on any other car in the past. I took the picture of the caliper and type of tools used are discussed in that thread. Let me know if you need anything else. Enjoy safe brake replacement.
Regards.
K. Atwal
Old Aug 14, 2010 | 02:23 PM
lkchris's Avatar
'10 CL550, '12 GL550
Tip #1: do nothing without reference to http://www.startekinfo.com/StarTek/o...tedDocId=11498
Tip#2: replace rotors every time you replace pads.
Old Aug 14, 2010 | 04:15 PM
atwal's Avatar
I was not aware of this requirement. Is this recommended or required by the maintenance manual?
Old Aug 14, 2010 | 06:09 PM
Greul's Avatar
Roll pin removal tips....HELP
I got the pads and finally got the caliper off after using a 3/8 in socket extender to hammer out the roll pins....but, cannot seem to budge the roll pins out the back of the shaft due to them hitting the rear flange. Any suggestions as to how to remove the roll pins?
Old Aug 14, 2010 | 06:51 PM
atwal's Avatar
9mm hex in the front....7mm hex in the rear for my GL450
Old Aug 14, 2010 | 08:32 PM
Greul's Avatar
Got the roll pin issue resolved. How many ft lbs should the caliper screws, brake assembly and lug nuts be tightened to?
