GL 450/ 550 Fuse Chart
Last week I was messing with some wires that connect to the middle front cigarette lighter. Anyways, I believe I shorted the wires and that may have led to a blown fuse. However, I don't know which fuse or fuse box to check.
May someone please post a picture or send me the fuse chart for a 2008 Mercedes GL? I have a 2008 GL550 and desperately am in need of the fuse chart. I'm assuming the 450 should have a similar fuse chart. |
There should be a fuse chart in the rear storage compartment (where spare usually is). Fuse is probably on the passenger side or rear compartment area.
Sorry, I forgot to mention. I got the car used, chart was missing at the time of purchase. I've just pulled and tested all the fuses on the passenger side. However, in the back there are too many fuses.
I'm in the same boat and my parts guy couldn't find a part # to order one for me. If somebody could scan one, I'd appreciate it.
On my 2007 GL450 the "cigar lighter" fuse is #46-15amp, which is located "in the trunk,on the right side".
Just replaced blown fuse#46 in the trunk (15 amp). Appears that only the ash tray lighter outlet is on this fuse and it is only powered with the ignition. The other three 12v outlets appear to be powered all the time. Be sure to switch the ignition ON when you are testing for power in the ash tray.
Thanks for the Fuse Schematic
To others looking - i was searching for my 2009 GL450! The Fuse Diagram was perfect!!!!
Many thanks for posting! I've now saved it for future reference! |
gl550 fuses diagram
Originally Posted by mbrandon
(Post 4623787)
GL 450 FUSES CHART
Hi
I need urgent the fuses chart for my mercedes GL 450 I bought it and dont have this. I have a problem the front seats dont works and also the GAS meter is not working I want to check first if is a fuse before sent to the mechanic Thanks |
Originally Posted by mariog25
(Post 7593867)
Hi
Looking for help here too....None of my 12v cigar lighters seem to work, but I checked fuse 46 and seems to be just fine. The 120V power in the trunk works, but thats about it.
Any other suggestions? Thanks all |
Originally Posted by Iceytys
(Post 7719942)
