LED license Plate lights
Old Nov 18, 2014 | 02:06 PM
zackadoodle's Avatar
2014 E-350, 2010 GL-450
Any recommendation on source for non-error code LED license plate lights?
Old Nov 18, 2014 | 02:09 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Amazon.com: Led License Plate Light Lamp for Mercedes-benz W204 W212 W216 W221 Brand NEW: Automotive Amazon.com: Led License Plate Light Lamp for Mercedes-benz W204 W212 W216 W221 Brand NEW: Automotive
not sure if it'll fit x164...
Old Nov 26, 2014 | 03:08 AM
nachilus's Avatar
09' GL550, 05' S55 (sold), 04' Yukon Denali XL, 05' 745il (sold), 01' 740il (sold)
Any luck with these?
Old Nov 26, 2014 | 10:39 AM
2010GL550's Avatar
GL550
I fairly certain those won't fit the X164. I have a 2010 GL550 and the license plate bulbs are the festoon type.
I tried these and they didn't work (still got errors in MID "license plate bulb error"):
Amazon.com: 2x 38mm 5050 3 SMD White Error Free Festoon LED Light Dome w Heatsink: Automotive Amazon.com: 2x 38mm 5050 3 SMD White Error Free Festoon LED Light Dome w Heatsink: Automotive
Old Sep 30, 2015 | 06:15 AM
eclassportugal's Avatar
E250 CDI AVANTGARDE 2010 - E200 CDI AVANTGARDE 2014 - V220 CDI AVANTGARDE 2014
hey guys do you know if i buy the new 2013/2014 Led for the license plate for my 2010 e class, do you know if they work and plug? will I get an error message? mine has the normal t10 lamps but I want to change it to led.
Old Sep 30, 2015 | 12:07 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Our T10/194 V5 wedge LEDs will work and won't throw any codes. Will output a crisp white light
http://www.aznoptics.com/index.php?m...products_id=95
Old Oct 11, 2015 | 07:52 PM
kriszto's Avatar
2012 GL 350
AZN Optics, do you have a LED bulb for a 2102 GL350 license plate that error free? It's the 36mm Festoon type i believe.
Old Oct 12, 2015 | 12:52 AM
AZN Optics's Avatar
Unfortunately, newer ML/GL model rear SAM actually has different spec compared to all other MBs (and even the front SAM!). This means that pretty much all normal canbus units you see out there will throw codes and you have to tap in external resistors to pull enough current to not trigger errors. We've been working on a plug and play design, but the higher current draw required generates too much heat right now. We're still working on it though.
