2 speed transfer case leak
My Car: GL320 CDI 2007 - just turned 10 and love it.
The car has the OFF-ROAD package on, so 2 speed Transfer case with lockable centre and back.
122.000 KM
I have notice the leak on the oil+filter change, not sure for how long it happened, no oil under car.
Troubleshooting so far:
1. Try to top up with MB236.12 a week or so ago. When open the top bolt it did like a coke bottle for about 3-4 seconds. The pressure was high as it start leaving the air out after only 2 turns... there was no need to top it up, it was actually above the hole. So I put the bolt back up.
2. checked wis and seems there is something on the top of the case, so I assume it's a there for this purpose (to let the air out).... Check it with the hand, it spins and moves free. Everything under the car is clean as, I leave in Sydney west - 60 KM from the sea, so the car doesn't get snow, too much salt breeze, maybe just a bit of rain from time to time; a lot of sun though.... not bragging...
3. order Liquid-Moli fluids for all; front diff, transfer case and rear diff to change them all...
Front Diff: LIQUI MOLY 85W90 Hypoid Gear Oil LS GL5 - 1.1L - Order 2 bottles
TC: LIQUI MOLY Top Tec ATF 1600 - 1.6L - Order 2 bottles
Rear Diff: LIQUI MOLY Top Tec ATF 1900 - 1.5L - Order 2 bottles
When I open the TC again to replace the oil, after a week, same thing again, under pressure. For last week wasn't leaking too much, I have seen only a drop, maybe from what was between the gearbox and transfer case.
Easy to replace the oil in them as in my case all have 2 bolts and the bottles come with a straw fitted under cap, so just drag the straw out of the bottle and squeeze the bottle in the diff/TC (no other tools required)...
Service details you can get from this post: https://mbworld.org/forums/gl-class-...our-fluid.html
4. Checked with local MB dealer: 120$AUD input shaft seal; about 8000$AUD for Recondition Transfer case; about 9500$AUD for new transfer case (but he never seen one as MB always replace with "Factory Reconditioned" in Germany); all this without labor.
So I'm seeking some advise: Is it ok for the TC to build up pressure? Has anyone seen/have this problem?
On oils- why different oils for front and rear diff? An off-road package requirement? Also why experiment with fluids and not use mb fluids? Just wondering.
ive seen two speed tcs in the states
MB dealer quote over 500$ AUD for the same type oils. So naturally paying over 110$ per litre of oil for the rear diff, I had looked around for different sources. End up buying Liqui-Moli as there were on special here and payed 177$ AUD for all. However, I'm planing changing them every time I do the gearbox oil and filter, about 50.000km.
The rear diff in X164 with off-road package is different from the front, it has the option to be locked for off-road use. Wis has listed like that, all different, I tried to find compatible version and Liqui-Moli was the only one to even suggest something to use. Wis has only one listed, MB235.15.
