beating a dead horse, can we use staggered fitment ?
hey all, I'm really itching to change out the stock wheels on the truck ... I picked out a rear size thats very close to the stock size, see below: but I'm consistently coming accross threads that ask people to refrain from using staggered fitments - my question is can I use the 305/45-20 in the back like the X5 has wider ones in rear ? Or in worst case use all four 305s ? How would the ride be impacted ?
Stock Tire Size - 275/50R20
Imperial Metric Section Width:
10.83 in
275.00 mm
Rim Diameter:
20 in
508 mm
Rim Width Range:
7.5 - 9.5 in
Overall Diameter:
30.83 in
783.00 mm
Sidewall Height:
5.41 in
137.50 mm
Radius:
15.41 in
391.50 mm
Circumference:
96.85 in
2,459.87 mm
Revs per Mile:
674.74/mi
Actual Speed:
62.14 mph
100.00 km/h
Speed Variance:
Diameter Variance:
Tire Size 1 - 305/45R20
12.01 in
305.00 mm
Rim Diameter:
20 in
508 mm
Rim Width Range:
9.5 - 11.5 in
Overall Diameter:
30.81 in
782.50 mm
Sidewall Height:
5.40 in
137.25 mm
Radius:
15.40 in
391.25 mm
Circumference:
96.78 in
2,458.30 mm
Revs per Mile:
675.17/mi
Speedometer Reading:
62.18 mph
100.06 km/h
Speed Variance:
0.06% too fast.
Diameter Variance:
-0.06%
10.83 in
275.00 mm
Rim Diameter:
20 in
508 mm
Rim Width Range:
7.5 - 9.5 in
Overall Diameter:
30.83 in
783.00 mm
Sidewall Height:
5.41 in
137.50 mm
Radius:
15.41 in
391.50 mm
Circumference:
96.85 in
2,459.87 mm
Revs per Mile:
674.74/mi
Actual Speed:
62.14 mph
100.00 km/h
Speed Variance:
Diameter Variance:
12.01 in
305.00 mm
Rim Diameter:
20 in
508 mm
Rim Width Range:
9.5 - 11.5 in
Overall Diameter:
30.81 in
782.50 mm
Sidewall Height:
5.40 in
137.25 mm
Radius:
15.40 in
391.25 mm
Circumference:
96.78 in
2,458.30 mm
Revs per Mile:
675.17/mi
62.18 mph
100.06 km/h
Speed Variance:
0.06% too fast.
Diameter Variance:
-0.06%
