2011 GL350 DPF differential pressure sensor location?
Old May 5, 2017 | 10:58 AM
rayray999's Avatar
Saab Crazy
Can anyone guide me on where this is located ?
Old May 5, 2017 | 05:27 PM
goalie_k's Avatar
2012 GL350
Follow the pressure lines to the sensor (on the sprinter its on the right front side of the engine)
Old May 5, 2017 | 11:09 PM
KrustyKustom's Avatar
2021 V167
On GL it is on the firewall slightly passenger side. Has one plug and two small lines (tubes) going to it. One 10mm bolt holds it on.
Old May 6, 2017 | 02:46 AM
rayray999's Avatar
Saab Crazy
KrustyKustom,
It was right were you said it would be! ... Thanks ....
Took me about an hour to replace it.
Steps:
1) You need the usual tools (ie: clam tool, the sockets, etc)
2) Take sway bar off
3) Take passenger side air filter housing off
4) You will now have room to work on the sensor, and clamps on the hoses (see pic)
5) reverse steps
6) Clear CEL (Ours was P2454)
By far the hardest part was undoing the 2 hose clamps on he sensor, as there is very limited room to work around.
Thanks everyone for feedback ...
Old Mar 17, 2021 | 10:18 PM
mbp's Avatar
mbp
mb
Would you please advise on how you remove the hose clamps? I'm planning on replacing the dpf pressure sensor on my 2011 GL350. Do I need any specific tools to remove all relate parts to get to the sensor?
