Cheap DIY to replace a leaking A/C line !
Old Jun 25, 2017 | 06:55 PM
JR-GL350's Avatar
GL 350 2010
At the beginning of the summer, tried my A/C without luck, no cold air. After paying $200 to find the leak, the mechanic told me I have to replace the complete line from the engine to the back of the car, in order to do that, they have to remove the exhaust, the fuel tank, the transmission, etc, more that 10 hs job and they don't want to do that job, to much trouble, so he send me to the MB dealer.
The leak was inside the left rear fender cover.
At the dealer it's may be around $2500- job.
So I found a company on eBay that sells kits to cut and replace part of the line.
Paid $38- for the part, 30 min job, $20 for the freon and oil. Done!
This is the company: https://www.autocoolingsolutions.com...ne+Repair+Kits
Old Jun 25, 2017 | 08:32 PM
gl450x164's Avatar
gl450 530i
Nice to
Nice to see people doing diy on these
Old Jun 26, 2017 | 01:22 PM
alx's Avatar
alx
Very nice and efficient.
Thank you
Old Jul 12, 2020 | 11:12 PM
RSD911's Avatar
GL550 X164
Hi. Do you remember what size of hose you pruchased. I have the same leak.
Old Jul 12, 2020 | 11:17 PM
JR-GL350's Avatar
GL 350 2010
Hello, I found the invoice:
TR10 A/C Line Repair Kit 5/8"
36 inch repair kit TR10-36C
Have a good one !
Old Jul 31, 2021 | 07:25 AM
hamazz's Avatar
GL320 ML 350
Hi
I took my GL320 to regas the ac last week, 2 days later there was no freon left, took it back to the shop, they tried to trace all the lines, compressor and evaporator for any leaks using the dye they put in when regasing, no dye showed up anywhere.
Got them to do a nitrogen test, it held for about 20mins, then slowly started leaking.
im thinking i might have the same leak, Did your GL350 have a rear split ac system with separate evaporator etc?
Hamazz
