Lower Oil Pan Removal For GL350 disel BlueThech
I posted it somewhere, I'll try to find the whole thread. Here's the doc anyway.
https://mbworld.org/forums/gl-class-...y-appears.html
This thread, second post from the bottom, also has the doc for the pan sealing instructions that are linked in the removal doc
Rod B (07-09-2018)
Thanks for the info! Wow, I have to raise the engine? Have you done this procedure? I do have a lift, so may be able to support the engine from below and lower the rest of the car (will have to look if that's possible), but I don't have an engine hoist. Boy, this is not going to be fun!
Any tips would be appreciated!
Cheers,
Rod
Yes, I suppose that makes a lot more sense. Wasn't really thinking it through... Will go take a better look. Thanks for the tips and for posting the procedure, that's a great help!
Cheers,
Rod
Cheers,
Rod
Raising the engine usually only requires an engine crane. If you don't have one perhaps you can borrow/rent one.
Many times you also need an engine support which is essentially a bar that spans the engine bay and supports the engine once you've raised it up. You can get those at places like Harbor Freight pretty inexpensively.
Before you go lifting the engine, I'd thoroughly clean the pan area (you have to remove the insulation first) and check it a few days later to verify the source of the leak. This engine is prone to leaks from above which work their way down to the pan.
