Battery drain overnight
Old 03-22-2018, 10:36 AM
JR-GL350's Avatar
GL 350 2010
Exclamation Battery drain overnight
Hello guys, I'm having a problem of a electric drain overnight with my GL 350 2010. Goes from 12.4 to 10.8 or less in 10 hours and I have to boost the car to start.
New battery, alternator OK, tested and removed all the fuses with the AMP tester and there are ok(Parasitic test).
The AMP test give me 0,4 and around each 10 sec goes up to 2,8. It's cyclic, up and down each 10 secs.
2.87
0.41
The only way to stop this was removing center connector in the rear SAM but with this a lot of functions are disabled too.
I suspect is related to the air matic suspension. When I reconnect the battery, lock the car, AMP tester connected, after 5 to 10 min I can hear a some kind of compressor sound in the engine and after that the up and down electrical consumption start.
Any clues ? ?
Could be a defective SAM?
TIA !
Old 03-23-2018, 06:24 AM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
OMG ,its like Chasing a ghost when one tries to find a short in system somewhere. Wishing you luck.
If you think it is compressor, you can try to disconnect compressor fuse (big orange one) and/or compressor relay (light green next to fuse). And see if it still uses excessive amps.
the usual technique is to disconnect the systems (take out the fuse) one by one and finding the culprit system that drains a lot of Amps. But it is not an easy find usually. Depends on how much time vs money you got.
JR-GL350 (03-23-2018)
Old 03-23-2018, 08:30 AM
DennisG01's Avatar
'08 GL 320 CDI
If the sound is happening every 10 seconds, can you just follow the sound to the item that is causing the issue?
Old 03-23-2018, 02:00 PM
JR-GL350's Avatar
GL 350 2010
The sound in the engine bay it's only when the cycle start, after 5 or 10 min with the car "locked", after that there is no noise, just the voltage up and down each 10 sec.
I think I need a priest now!
Old 03-23-2018, 05:54 PM
DennisG01's Avatar
'08 GL 320 CDI
Oh, OK, I misunderstood - I thought the sounds was happening every 5-10 seconds. I know what you mean about needing a priest - electrical gremlins can be real buggers. In the past, when something like this has stumped me, I've done the same thing that TX mentioned... just start pulling fuses one at a time. You'll find it - SOME fuse has to control it!
Old 03-24-2018, 06:22 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Maybe one of the doors sensor that is not working, if one of then send the message that the door is open, although it is closed, this maintains the electrical system of the car activated consuming the battery.
Quick Reply: Battery drain overnight
