While I知 in there suggestions for oil cooler seals
Old 04-14-2018, 04:32 AM
smiledr996s's Avatar
2008 gl320cdi
Soon I値l probably have the oil cooler replace, pretty sure source of an oil leak. I知 also at 165k, so I would like to replace anything that would potentially be an issue in that area or coming soon. while in the shop. I depend on my vehicle so willing to replace before necessary to a degree.
Looking for for input and suggestions. TIA
Old 04-14-2018, 09:39 AM
BlownV8's Avatar
Received 1,000 Likes on 807 Posts
E55, GLS450, GL63, GLE350
Timing chain could be stretched but it doesn't seem to happen on all the diesels.
Old 04-14-2018, 10:45 AM
chsu74's Avatar
GL 320, 993TT, BMW 550XI
Timing chain is not even close to oil cooler repair work. I would replace the swirl motor with new clips for peace of mind during an oil cooler replacement. My swirl clip to bank 2 of intake manifold came undone in my GL320. Will replace it myself when weather gets warmer.
Old 04-14-2018, 11:04 AM
2008 gl320cdi
Thank you for the replies. I had asked both in there and mileage. I think Blown was indicating the latter. I do plan to have checked, I am hoping not an issue. I always thought chains were longer lasting. Since I have a tune I am planning to have the swirls deleted and welded up as well as egr delete. I am eager to see if my intake is full of tar and better performance after clean up. It’s possile the leak is just slow runoff after my oil cap leak. I added oil while engine cold and guess the seal was bad. No more issues after new cap. I don’t think the seals have ever been changed so at 165k it has to be close unless there are those that get easily over 200k
I was curious if anyone has changed water pump. I don’t hear much mention about. I hear an occasional squeal when turn off the engine. I figure maybe pump or belt roller or tensioner. Again at 165K all original. I am hoping for over 300k
Old 04-20-2018, 05:57 PM
007_e350's Avatar
X166 gls450 2017
i would clean the intake manifold and valves of carbon residue, I suggest walnut blasting
Old 03-03-2022, 12:03 PM
nilknarf's Avatar
2008 ML320 CDI
I've also wondered about the water pump as my ML is over 183k now. They never seen to last 100k miles on various other German cars that I've owned. I searched a while back and didn't find many posts about the water pumps on the W164 cdi's. I guess they are really robust. Keeping an eye out for the day it begins weeping coolant. You're probably due for a belt tensioner and idler pulley.
Quick Reply: While I知 in there suggestions for oil cooler seals
