2011 GL550 AC Blows warm on driver side only
Strange problem started about two weeks ago, brushed it off at first, but it's getting hotter. Now its becoming uncomfortable to drive. Anyway, it's a 2011 Gl 550 with rear a/c. The passenger side vent and rear air is cold. I took a temp reading at the vents and got the following:
Outside temp: 94 Driver vent: 85 Passenger side vent: 71 Rear a/c: 72 I do have a iCarsoft scanner, I checked for any faults and they were no stored or active codes. I also viewed the actual value data of the left and right blend door. Both of the actual values match the output values of the climate control. I do hear it change position when putting the climate to hot and cold. I do see after searching that on other mercedes a low refrigerant charge causes similar problems, however I'm having a hard time believing that is the cause in my case. Has anyone had a similar problem on the 164 chassis? I am tempted to put my gauges on and add a little more freon just to see what happens. Any help or thoughts would be greatly appreciated! Edit: forgot to add, the driver side DOES get cold randomly during longer periods of driving. But it will get hot again randomly as well. |
Don't be foolish and add anything until you determine that is what the gauges indicate-----an alternative is find someone with factory diagnostics and the problem will be quickly found.
I had a similar issue of random side differential cooling except the passenger side cooled while drivers side was warm. Eventually it quite cooling all together and replacing the a/c compressor was the fix.
Originally Posted by mefferso
(Post 7469270)
If you find out it is the compressor and want to save some money, here's a writeup I did on the installation: https://mbworld.org/forums/gl-class-...ement-diy.html
It was about $450 in parts doing it myself. |
in the W211 there is a switching valve that goes bad, and you will get hot air from the rear and cool air in front. is it possible this is the issue with the GL as well. I will do some research on where that valve is in the GL.
Originally Posted by thtguy
(Post 7470343)
Originally Posted by niL
(Post 7470522)
That would be much appreciated!
I had this same issue in my GL500 (Australian version of GL550). Just needed an AC regas. Completely removed existing gas, filled with new gas and flouro dye. Went back a few weeks later and couldn’t find a leak. Has been working perfectly since then. |
I have the same issue in the same exact car. Just started a few weeks ago. However, if I turn on the rear air, I get cold air all around. Also, on a long trip last week, the air flow all around diminished to almost nothing. Turning the air off for a few minutes then back on again seems to rest it. The dealer says it is the evaporator and wants $4,000 to replace. I can’t figure out how turning on the rear air would at least temporarily solve the problem. If the evaporator is bad, wouldn’t we just get warm air all the time? |
Most likely low refrigerant due to some leak. Seals dry up over the course of years.
https://www.walmart.com/ip/A-C-Pro-P...ornia/36158903 Buy this recharge kit. Check pressure after turning on the AC on full blast. If it is in low range, recharge it. There might be a small leak. If it is in red range, DO NOT add refrigerant. OR take it to dealer or shop to properly diagnose it. |
Originally Posted by TX07GL450
(Post 7486793)
(Post 7468468)
Usually a leaky evap in those trucks, yes. Left side is further away from the TXV so gets hot first. only seeing 20 degree cooler temps on pass side is not good anyway, should be close to 40 degree temp drop on a working system. Find a local a/c shop that will do the Evap cheaper.
(Post 7468468)
Originally Posted by will6708
(Post 8386073)
On my 2009 GL550 this exact same scenario started today. 7/30/21 Did you ever reach a consensus from this thread for an answer that solved the problem? I just bought an ICarSoft ll 3rd generation scanner but haven’t had time this afternoon to hook it up.
Then that's where I'll start. Thanks for our input.
