Air suspension Malfunction error
Hi,
For the last couple of weeks, I am getting a message on my 2012 GL450 with a SUV sign up arrow and text Malfunction. But all 4 of my suspensions are normal height. I get this message seems to be 30mins into a drive each time. It is in white text and you can click out of it from the wheel left and right button. It is only a Message. I had front and rear air structs replaced with OEM parts only 6 months ago at dealer. Any suggestion on what could be the issue and if it is urgent? Thank you so much!
Hi,
Could be a lot of things but I would only be guessing.
If you got it fixed at the dealer you have a 2 year warranty on repairs.
I would tell them to sort it. You spent a lot of money there.
I would look for burned out or cracked compressor and Stuck leveling rods
evan8 (03-13-2019)
If you are not close to a dealer, find an auto parts store with a code reader. That should give you a little better idea of precisely which part(s) are creating the message.
evan8 (03-13-2019)
I had this recently and read the codes. It was a failing air compressor. I believe the error was 5503 which essentially said that the compressor was unable to fill the reservoir (i.e. the air tank in the back.)
A replacement compressor from Arnott was about $280 and cleared the message. I'm lucky enough to have a nice diagnostic tool because this is not a generic OBD code, it is Mercedes specific.
evan8 (03-13-2019)
Hi, thank you for your response and apologize for the slow response. My local shop told me they would use Arnott and would be around $750 for total cost. Would you mind sharing why you went with Arnott compressor vs. OEM? My OEM lasted me now 7 years and now started to fail looks like.
evan8 (04-04-2019)
