Problems starting my 2007 Mercedes Benz S550
Old Mar 24, 2019 | 10:05 AM
10grandsport's Avatar
S550
Starting my 2007 Mercedes Benz. While holding the break down and pushing the start button then car cranks but won't start. Have to repeat the starting procedure many times before the car will finally start.
Old Mar 24, 2019 | 10:51 AM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Wrong forum but same engine as our gl550 owners.
Original battery and starter?
Old Mar 24, 2019 | 11:06 AM
DennisG01's Avatar
'08 GL 320 CDI
If it's turning over normally (fast), then I would first suspect a fuel delivery problem. I'm not familiar with your engine, but any other engine I've ever messed with has a Schraeder valve where you can hook up a pressure gauge to check fuel pressure.
Any codes?
FYI... it's a "brake"
Old Mar 24, 2019 | 11:17 AM
S550
Thank you. Battery is 2 years old. Never replaced starter.
Old Mar 24, 2019 | 12:14 PM
DennisG01's Avatar
'08 GL 320 CDI
You didn't mention "how" the engine is turning over... normal speed? Just because the battery is 2 years old, doesn't mean it's still good.
