Recommended power steering pump brand
Old Jan 11, 2020 | 05:07 PM
rdbrown31's Avatar
2008 GL 450
Hey guys,
I’m going to take on installing a new P.S pump myself. What brand do you recommend? What are your thoughts on re-manned units?
also, other than serpentine, what other components do you recommend changing at this time?
thanks for all the great feedback on my questions thus far
Old Jan 11, 2020 | 09:16 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by rdbrown31
Hey guys,
LUK or MB original. Don't use a cheap chinese product or you'll by doing it again.
Curious - why are you replacing the pump?
Every GL will eventually develop a leak from the power steering reservoir that can often be misdiagnosed as a power steering pump leak. The fix is a new o-ring for $3.50.
If that leak goes unchecked for long enough, then yes it is time to replace pump.
Old Jan 11, 2020 | 10:38 PM
rdbrown31's Avatar
2008 GL 450
I’m unopposed to just changing the o-ring first.
I just got the car and I’m doing some tuning up. It’s a 2008 GL 450. While under there giving it an oil change, I noticed a lot of oil underneath on the drivers side, not related to an engine oil leak (I don’t believe anyway) and ps fluid was really low. After filling it still has hard steering at slow speeds, and there’s a noticeable whine in there. Not loud or pronounced, but even on new-to-me cars, I tend to “listen” to them, so to speak.
I’ll change that o-ring and clean all the under chassis the best I can, and respond accordingly.
thanks for the response.
Old Jan 11, 2020 | 11:44 PM
Max Blast's Avatar
NGL450 w/EORP, S550
yeah I’d give the oring a shot before doing the pump.
check your reservoir for cracks as well - they’re only about $70 from Mercedes.
Old Jan 12, 2020 | 04:51 PM
lkchris's Avatar
'10 CL550, '12 GL550
You’ll note on the M273 engine that the engine oil cooler is very near the power steering pump. The gasket between this and the oil filter housing is known to fail, causing a visible oil leak. Visible elsewhere could be evidence there is mixing of motor oil and coolant, as the oil is cooled in the cooler by heat transfer to engine coolant. Inspect.
Im not unfailingly familiar with the GL installation, but I recently did this on the M273 in my CL. I had to separate the ps reservoir from the ps pump to provide clearance to remove the oil cooler, so it was obvious to replace the reservoir->pump o-ring too. You might consider proactively replacing both.
https://blog.fcpeuro.com/the-definit...d-m273-engines
