U0002 - Limp mode
2012 GL350
Voltage is good (replaced battery). Limp mode, U0002 code. Won't shift into gear, random wipers, it will start...
Thanks!
Yes Moisture in an external connector that should be weather proof.
Moisture combined with road salt likely caused some corrosion and some type of short that resulted in 2 bad sensors in the and the control module going bad (blind side monitoring). That in turn created the CAN bus error that would not allow it to move. Couple of thousand to repair / re programme / replace failed components.
