Master Cylinder accidentally ran DRY. Help!
So, I think I have empty brake fluid from the master cylinder to the LF (no fluid at bleeder screw).
What would be the correct procedure I need to do?
The MC bench bleeding (outside of the car) seems to be beyond my newbie DIY skill.
However, I have MC bleeder kits (https://www.dormanproducts.com/p-1646-13999.aspx) and a Motive Product Pressure Bleeder.
After some googling this week, my current plan to do is
(1) MC bleeding on the car using the bleeder kit,
(2) Gravity bleeding FL.
(3) Pressure bleeding RR, RL, FR, FL
Am I right or is (2)-(1)-(3) better? Anything I missed?
Also, I am not sure whether the ABS system bleeding at Dealer is needed after this.
Please help!
Thanks,
LL
Others will probably have more advice for you, there are a few mb techs here...
Please help!
Thanks,
LL
Gravity bleed cannot be relied upon. Bleed order:
1. right rear (passenger side North America)
2. left rear (driver side North America)
3. right front
4. left front
I did it yesterday. After (1) bench bleeding MC on the car and (2) pressure-bleeding all 4 wheels, my brake finally came back. I prepared 2L, but 1L fluid can was enough.
It is slightly soft, but it seems to run okay. No abs issues at all.
hopefully any remaining air bubbles will eventually find there way up to the master cylinder and dissipate
Mike
