Oil Gasket on front of OM642 valve cover
Old Jan 23, 2021 | 07:38 PM
Jason Stern's Avatar
Current: 2008 GL320, 2009 ML320 Past: 2006 E320 CDI, 1991 300D 2.5T, 1982 300SD
I'm not sure what this part is called (circled in red) on the front of my valve cover, so I was wondering if someone could tell me the gasket needed for this cover as shown in the photo and maybe a part #?
It started spraying oil this morning so I need to get it replaced asap.
Thanks in advance!
Jason
oil gasket broken
Old Jan 26, 2021 | 05:01 AM
feroz ahmed's Avatar
E320
i have same engine om642 the most powerful and reliable engine after few years there is only problems i faced engine oil leaksif you change all oil seals and joins of the engine you can enjoy it and it will increase engine life by stop taking air.
Old Jan 26, 2021 | 09:13 AM
DennisG01's Avatar
'08 GL 320 CDI
I'd have to try and research that one, myself. But I bet if you went to a local MB dealership with that picture (if you didn't want to drive the Merc there) they could get you hooked up. Or, call the service department and tell them you'd like to email a picture to them.
Old Jun 5, 2022 | 04:17 PM
2008sprinter's Avatar
sprinter 2008
Thanks in advance!
Jason
oil gasket broken
I am almost certain that is your vacuum pump
Old Jun 7, 2022 | 03:10 PM
Max Blast's Avatar
NGL450 w/EORP, S550
https://mbparts.mbusa.com/oem-parts/...hoCA-kQAvD_BwE
If no part number is returned from the dealer
