X30/7 Voltage distribution question
Old Oct 29, 2021 | 11:12 PM
Misha_'s Avatar
2012 GL350, 2014 GLK250
Hey guys, I'm tlretrofitting some AMG seats in my x164. The multicontour part of it requires a pneumatic pump be installed in left rear quarter. The pump has 3 connections:
1. Ground to the frame by the pump2. Constant 12VDC from rear fuse box3. 5VAC from front voltage distribution, labelled as X30/7 in starfinder.
can anyone provide some insight on the X30/7 component? What exactly is 5VAC?! Does the distribution come from a SAM where this feature needs to be enabled or it's just 5VAC split between all the connections on the distribution. Starfinder says that it's 5VAC on all connections pin2, and each connection has pin1 and pin2.
Any help is appreciated!
