Steering won’t lock and says remove key
Old Dec 4, 2021 | 05:20 PM
Saint0560's Avatar
2102 GL450
When you turn the key on my 2012 GL450, the steering column doesn’t lower to it’s set position and the car will not start. Message says “Remove Key”. The steering column isn’t locked at all. I see threads that say when you get this message, it’s the ESL. But all say column is locked. I would assume that if the motor failed in the “unlocked” position, then the car should start? Has anyone experienced this?
Old Dec 5, 2021 | 12:00 AM
wannawagon's Avatar
2006 ML320 CDI (2 of) and 2008 GL320
I have heard that a lot of the steering lock motors have been programmed to stay in the unlocked position.
do you have a second key you can try
