Why is my Transmission shifting weird
a few years back I had to change the conductor plate in the transmission.
i don’t know if what’s happening relates to that and I realize that somebody recognizing symptoms in this video is a shot in the dark but maybe I’ll get lucky
the buzz you are hearing is from a wire that’s not grounded but it amplifies the sound of the weird shifting.
any help would be appreciated
also what are symptoms of bad speed sensors? I haven’t heard of those being an issue
you’re locked in 2nd gear as long as this code persists.
if you wanna post up another video of said condition with no background noise perhaps we can offer a better remote diagnosis.
As the valve body comes up to pressure fluid can leak past the solenoids Orings causing erratic shifting. I have changed the Orings in 3 valve bodies and the bottom rings have all been weak. My 2008 GL550 has 130k miles on it.
Ok Cobra Transmission parts in Florida just got stock back in. $26 or so for the kit. Don’t forget to buy the 2 orange electrical connector Orings also.
I am going to put some packages together soon and sell them on my son’s ebay site where he sales R129 parts. OK I hope this helps… I spent pretty much a whole week searching for the proper Oring grades and sizes BECAUSE COBRA was out of stock . I went with
FKM V75 ( a high grade viton top and bottom Orings)
I looked into Cobras and they are Viton on the bottom and poly on top???
I believe or educationally guessing that the early MB Blue Orings on the bottom are a cheaper grade and can’t take the cold weather as well as the V75’s. V75’s go down to —20F and some early Vitons only go to +5F… my tranny went down on a very cold day.
Than of course to top it all off MERCEDES only sales the complete solenoid for well over $100!!! No Oring only sales. ok take care Bill
Don’t forget to clean the screens and bottom of the insertion area with a magnet. plugged screens can also act up the shifting patterns.
I used cheap roasting pans from the dollar store to hold the valve body while I removed parts.
I have a pile of tranny gaskets from all the fluid changes because in my belief it is the weakest link that we can maintain ourselves. I have changed at least 15 fluid changes anything from original MB, Fuch 134, Shell 134…. the last few have been Amsoil signature .. with unreal results . I ran my GL550 45,000 miles and it was red and spotless . I would highly recommend that anyone trying to maintain at least try it once. Once you buy the low cost membership the 2.5 gallon can cost $125… that’s $12.50 a qrt. The cheapest stuff was shell around $6 a qrt and it always looked brown and horrible no matter how many miles I put on it.
ok some more of my thoughts . Also just bought Wix tranny gaskets and filters from RockAuto and they looked real nice for $25 per set.
Back on valve bodies…
My GL550!has a 220-270-1906
2009 ML350 has a 220-270-2306
the new replacement for them from MB is 220-270-2706
I have read about different upgrades aftermarket drilling out certain spools etc… I believe the newer valve bodies have those features. The difference in the two I listed is quite different ..
