Ac started to act up, what to check 1st ?
Only thing I've done so far is checked the freon level and topped it up a little but still not blowing anywhere near as cold as it should be.
Anyone point me in the direction of a AC thread on what to check first/second/third etc
Look at the refrigerant hoses underhood to see if any are slowly leaking at the metal-to-rubber crimp.
I can hear the compressor turn on with no problem.
Thoughts?
it's time to put in a new compressor and drier. That's the only solution.
compressors and starters in GLs die a slow death.
Next job is i'm going to replace the compressor and dryer and recharge it, hoping that solves the problem.
please search this forum for diod issue with aftermarket compressors.
I got lucky and my aftermarket didn't give me any problem
Repair was $800 at my Indy.
Last year my AC was working fine. I have 3-zone climate control. All zones functioned well at the time. A few days ago it was hot enough to use the AC. I did not get the same cold air as last year. Had the system checked (hold pressure, hold vacuum) and fully recharged. The indy shop said it had no freon at all. AC is back in action after the visit to the indy.
