2012 GL550 no crank
Another concern is that you said you tried jump starting it. I've read posts about Mercedes that had computers or fuses damaged by jump starting. The original problem may have been a dead battery, but then the jump starting maybe caused a second problem?
Does the starter relay click when you turn the key? I think the starter relay is in the fuse box under the hood. Check fuses too.
I had to replace the starter on my 2010 GL450 earlier this year, but my symptoms were weak starting / slow cranking and I changed the starter before it totally died. Can you check the voltage at the starter?
Please update this post with what the problem actually was so we can all learn. Thanks!
Great site for fuse box intractive .. press the fuse or relay for info.
https://www.startmycar.com/us/mercedes-benz/gl-class/info/fusebox/2011
