Rain-X
Old Mar 8, 2013 | 12:38 PM
cookstar's Avatar
2005 ML350, 2008 GL320, 2013 Gl350
Rain-X
Has anyone applied Rain-X to the windows? just used some on my rear window today and I am impressed as to the results, the water slides right off without sticking to the window. I think what it does is close the pores in the glass. They also make it for paint as well but I dont trust it enough to apply to the paint.
Old Mar 8, 2013 | 01:04 PM
Mbenz260e's Avatar
2022 E450 Prior:2021 S580 2012 E350BT, 2013 GL350BT, 2009 ML320BT, 2006 E320CDI, 1987 260E
I've used it off an on over the years. Don't like it so much on my windshield as can notice slight haze and confuses the automatic wipers. Rear glass though and pano roof on my E i like it though don't reapply as often as I need to. To me it helps prevent water spots on the glass those times it rains then is sunny later on...
Old Mar 8, 2013 | 01:51 PM
cookstar's Avatar
Yeah I did notice the haze as well, thats actually why I did not apply it to the front window.
Old Mar 8, 2013 | 03:12 PM
fabbrisd1's Avatar
A gaggle of MB's
I am personally not a fan of RainX although there are those who love it...
On the exterior - if you got the MB "Paint Protection" (sealant) rain should bead up on the paint as well ... for those without a new MB w/o MB "Paint Protection" you can use Einszett Galnz Wax (Blue Top) sealant for same benefit incl "water beading" effect on the paint...
Keep the beat !
Old Mar 8, 2013 | 03:35 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Ditto!
Old Mar 8, 2013 | 03:56 PM
vertrkr's Avatar
2014 GL350 ordered
Use PIAA Super Silicone wiper blades to get the rain-x effect without the haze. I've been using them for 15 years. They are impregnated with silicone which deposits into the glass pores over time. They also last about 5 years. I just replace the stock blades with the piaa refills from amazon. I have not seen the GL blades yet so I don't know if it's an easy swap. Might have to buy the whole housing instead of the refill.
http://www.piaa.com/store/p/136-28-2...Pair-Pack.aspx
Old Mar 8, 2013 | 08:27 PM
sraza's Avatar
MBs
didnt like haze with rainx-- mb paint protectant or any high quality wax/polish help bead effect and no haze- i prefer that - been doing it for years.. also make windows pretty shiny too
Old Mar 8, 2013 | 09:56 PM
shpent's Avatar
clk 550 2007
Side windows ok and helps with snow /ice removal . Side outside mirrors bead up but wind can't remove beading . Do Not suggest for mirrors
Old Mar 8, 2013 | 10:15 PM
sraza's Avatar
MBs
helps tremendously with ice/snow/grime/salt removal-
yea i dont usually do mirrors (used to though)
Old Mar 13, 2013 | 02:04 PM
dougo01's Avatar
2005 230 Kompressor Coupe, 1977 Suzuki PE 250, 1977 Suzuki RM250, 1987 Toyota Supra
problem with rainex is that it doesn't last. Try "Aquapel" it's made by NAPA. Costs about the same and lasts forever. I never use my wipers above 40 mph...
Old Mar 13, 2013 | 02:08 PM
cookstar's Avatar
just looked it up, advertised as lasting 6 months, will give it a try!
Old Mar 13, 2013 | 03:37 PM
blittle's Avatar
I also use Aquapel..... on the rear window only, however.
