2013 GL550 Trailer Hitch
Old Nov 15, 2016 | 05:55 PM
srfrboy's Avatar
2013 GL550 4Matic
Can you add an aftermarket trailer hitch and lights to a 2013 GL550?
Old Nov 16, 2016 | 02:00 PM
Mike450's Avatar
2015 gl450
You can add a hitch and lights to any x166 GL, excluding active curve equipped.
Old Dec 17, 2016 | 09:38 PM
D Fuller's Avatar
Audi TT, Saab 95, GL wannabe
Does the added hitch have the same sway control as the factory? And how much does it cost?
Old Dec 18, 2016 | 12:27 AM
fabbrisd1's Avatar
A gaggle of MB's
1) A Curt aftermarket hitch + basic wiring hookup = estimated under $450 at a U-Haul location. They fit up hitch + basic wiring including brake/running-lights/turn-signals using a Modulite module w/hook-up to rear lights wiring. Often "best" hookup includes running hot lead back up to the battery. For "most" Curt installs their website has install instr and/or install videos for the hitch portion.
2) Check with your MB dealer for MB-hitch/MB-wiring harness - by VIN# they will also be able to tell you if you need rear SAM module as well. The factory wiring harness with proper SAM provides the MB/anti-sway. Now that harness does not come with printed wiring instructions - instr come from Star/MB-Tek - and runs about 5 "real" shop hrs.
Old Dec 19, 2016 | 10:21 AM
Mike450's Avatar
2015 gl450
Uhaul installed Curt hitch Fab mentioned above will not have anti sway feature. As mentioned, call dealer to see what is necessary for your particular car.
If a wiring harness to front of car is necessary, sit down before they quote you a price. It's gonna be north of $2k, as just about the entire driver side of truck's interior has to be removed to install it. There is a video in German on Youtube somewhere that details the install.
Old Dec 23, 2016 | 10:08 AM
Ericlojo's Avatar
'24 GLS450
This is the only mention I have found of this issue, is this true? If so, why? I have a 2014 GL350 with Active Curve and need to add the OEM hitch.
