2014 GL550 engine is hot after every ride
Old Aug 13, 2018 | 06:29 PM
divinefavor's Avatar
2014 gl550
i live in CA. weather has been somewhat hot, around 70-90 during the peak. my garage faces south west so it gets very hot during the day time. last week, i touched the hood few minutes after i parked my GL in my garage and it was very hot. i touched other parts of body and it was very cool even though garage was heated up. i noticed this behavior constantly after that. may be i'm oversensitive about this issue but when my wife drove off, the engine (not the exhaust) sounded louder than usual even at the start.
i do have one recall (Active curve system related) undone yet, but is there anything else i can check to see if this is normal?
Old Aug 14, 2018 | 03:42 AM
jacobsung's Avatar
18 Model X, 13 GL350, 13 Odyssey, 07 530i
Check the coolant/engine temp gauge from your dash. That's what it's important.
Old Aug 14, 2018 | 09:41 AM
NaviTimer1's Avatar
GL550
GL's tend to run hotter than other cars. How is your coolant levels? As Jacobsung mentioned, keep an eye on temp gaguge. I live in FL and close to the ocean, sometimes steam comes out of the body panels on really hot days.
Old Aug 14, 2018 | 01:18 PM
EricC21's Avatar
Gl450
In other news water is wet. Engines get hot.
Old Aug 14, 2018 | 01:35 PM
OrionS55's Avatar
2015 GL550 2006 S55
My 2015 GL550 temp gauge is very consistent, always at this level once warmed up.
Old Aug 14, 2018 | 02:27 PM
2014 gl550
where is coolant located on gl550? also i'll start paying attention to temp guage from now. normally i don't drive this car everyday, my wife does.
Old Aug 14, 2018 | 10:38 PM
OrionS55's Avatar
2015 GL550 2006 S55
Coolant reservoir
Old Aug 15, 2018 | 08:50 AM
novae500's Avatar
W211
after a 20 min drive and parked in the garage, the garage is very hot inside. probably cause of the twin turbos
Old Aug 16, 2018 | 12:19 PM
EdyCol's Avatar
2013 BMW X5 35d, 2011 VW Tiguan
Turbos do not have anything with it. I have twin turbo diesel that doesn’t dissipate heat nearly as much as my wife’s VW Tiguan with small 4 banger turbo.
It is the fact that it is gas (looses temperature much faster to outside then diesel for example since it is aluminum) and the fact that it is fairly big engine.
It comes handy in cold states. Could serve as a heater for garage
Old Aug 16, 2018 | 04:59 PM
NaviTimer1's Avatar
GL550
It looks normal, standard for this engine.
Old Aug 16, 2018 | 05:08 PM
NaviTimer1's Avatar
GL550
If it gets really hot, the instrument cluster will notify to pull on the side of the road and turn the engine off. I've personally never experience it but I read it in the owner’s manual, I was also concern when we first purchased it.
Old Aug 16, 2018 | 08:00 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Old Aug 16, 2018 | 08:16 PM
OrionS55's Avatar
2015 GL550 2006 S55
yeah I was just letting him know this is the normal temp
