Check Coolant Level Message
Old 01-23-2019, 08:59 AM
novae500's Avatar
W211
Good morning
Went to start the car to go to work and saw this message come up. Anyone get this code and did you have a coolant leak? Need to setup a service appt with the dealer to check it out. Only have 37k miles on 2014.
Old 01-23-2019, 09:09 AM
BlownV8's Avatar
Received 1,000 Likes on 807 Posts
E55, GLS450, GL63, GLE350
Probably your coolant line to the turbo that is leaking. Any wet spots under the GL?
Old 01-23-2019, 12:22 PM
novae500's Avatar
W211
i didnt see any seepage or leaks.... did a search and saw that several others had this from either a cracked y inlet pipe or cold temps. Been in the single digits past several days.
Quick Reply: Check Coolant Level Message
