Battery Recondition
Old Dec 2, 2019 | 02:33 PM
dalukas's Avatar
2014 gl350
Battery Recondition
I've got a 2014 GL350 that has about 75k miles and the battery is starting to go. I recently bought a CTEK charger and did a normal charge but am still experiencing very slow motor crank after sitting overnight in an unheated garage with ambients temps around 25 degrees. Was thinking about trying the recondition mode with the CTEK. Has anybody done that and if so has it helped? Can i do it without pulling the battery which is a pain? And the last question is how long does that mode take? Thanks for any feedback.
Old Dec 2, 2019 | 04:41 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Your battery is 5 years old. That is pretty much end of it. Just buy a new battery.
Old Dec 2, 2019 | 08:07 PM
fabbrisd1's Avatar
A gaggle of MB's
YES - buy a new battery... you are lucky you are getting a "slow crank" warning - most times the battery drops below operating voltage - and you get GL-does-nothing-when-I-try-to-start..
Old Dec 2, 2019 | 09:38 PM
chassis's Avatar
2017 GLE350 4MATIC
Batteries have a finite life, they don't get cured by a charger. Time to buy a new battery.
Old Dec 3, 2019 | 10:14 AM
dalukas's Avatar
2014 gl350
i'm not against getting a new battery but was just curious. I know the agm batteries are a bit different than the wet kind. The CTEK is great for stored cars as it will do a pulse charge and not overload the battery like a normal trickle.
