Lift Gate Not Respoding
My lift gate button, the inside door switch, and remote are completely unresponsive. No sound even from the actuator or anything.
Two questions:
1. How do I manually open the trunk?
2. Where is the fuse box for the x166 2013 gl450?
Thanks!
After confirming fresh batteries, there are three modules to be aware of: liftgate control unit N121/1, rear fuse box F4 and rear SAM N10. The liftgate control unit is on the right (passenger) side wall behind the trim panel. I haven't located F4 or N10, but would start in the rear side wall and rear spare tire areas.
Can you read codes, ideally using a Xentry/DAS system? Sounds a little like a bad liftgate control unit, but there is more diagnosing to do.
I found the rear fuse box, it is under the middle row of seats, on left side. I checked every fuse using a voltmeter... they are all 100% fine. I then proceeded to check every fuse on the other two fuse boxes -also fine!
Where is the lift gate control located? It is very had to acces the rear cargo area if the trunk cannot be opened!
I ordered a icarsoft reader. It noted the below error code:
I am having doubts whether this is SAM related. The rear SAM controls tons of stuff. Why then is only the tailgate having issues?
What about this module? Not sure where it is but will search for it next.
When the liftgate is closed, what method is used to open it?
Sounds like a point failure, rather than a system failure. Seems like the latch has a bad switch, or the lift cylinders are getting flaky. Do the lift cylinders function correctly, other than the failure to open when closed situation?
A new liftgate control module is $300, compared with your eBay example of $90. If it were my vehicle, and I was 100% sure the liftgate module was bad, I would order a new one and not take the chance on a used piece of electronic equipment.
What "close trunk lid" button do we think that is? The one in the drivers door, or the one in the rear compartment? Hopefully not the one in the trunk its self. if i push and pull on both buttons, the trunk will release but not actually open. I have to open and close it manually. It sounds I am manually moving the motor, gears when I do this.
Would the dealer software give better info?
Also, should the Icarsfot I980 be able to reset the service interval? I cleared the codes and I still have the A9 code showing on the dash. Is there a way to clear codes?
Finally, does anyone know what the Position 1,2,3,etc are on the Icarsoft?
Thanks for the help.
- key fob
- driver's door button
- button on inside of liftgate
- button outside of liftgate above license plate
The generic suggestion for diagnostic systems is to use Xentry/DAS. Other systems will work, partially.
I am going to order a new one, does anyone know if I need to get it programmed to the car or will it plug and play?
Hopefully this fixes it once and for all.
Also, not what the carsoft suggested, interestingly.
For other sensors and systems (windows, steering wheel sensors), normalization is a manual (non-coding) procedure whereby limits of travel are established.
great news!! Thanks, the module will be here next week. Hopefully save me a trip.
Edit: This was a response to an above suggestion on using the mechanical key to open the hatch.
Last edited by fishinjdb; Dec 24, 2020 at 01:22 PM. Reason: To clarify what I was resounding to and add a question.
I am facing a similar issue. The trunk won't power open or close. I can hear the motor in the strut working when I press any of the buttons. I can also open/close the trunk manually without any problem. Were you able to hear the motor in the right strut working when you pressed any of the buttons (fob, driver, trunk)?
Thank you
LL
