Driver's Side Intake on Hood
Old Nov 29, 2020 | 08:59 AM
Von Hayek's Avatar
GL450
Can someone please tell me what the intake on the driver's side of the hood feeds? I just got a 2013 GL450 from my brother, and a walnut had fallen from a tree, smashed through that intake, restricted the opening, and pieces from the plastic grille have passed into the tube that it feeds.
Old Nov 29, 2020 | 12:42 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Picture of said intake?
Old Nov 30, 2020 | 07:45 AM
Von Hayek's Avatar
GL450
The one on the right...
Old Nov 30, 2020 | 04:32 PM
Bern6389's Avatar
2014 GL350 Bluetec X166
holy cow. On the bluetec, it’s a water drain. Open the hood and see if you see a small rectangular funnel.
Old Nov 30, 2020 | 08:05 PM
BlownV8's Avatar
On the 450, it serves a dual function as the heat exchanger for your blinker fluid and muffler bearing carrier coolant. If you let it go unrepaired, it can cause faulty installer valves and can also damage the European 30 weight ball bearings from your muffler bearings. You look to have received one of the early model heat exchangers made in China since the ones made in the US are of higher quality and will resist impacts like this. I'm sure there are those with more experience than I so correct me if I'm wrong or have missed anything.
Old Nov 30, 2020 | 08:08 PM
Von Hayek's Avatar
GL450
Hah! I'll get that checked out.
Old Nov 30, 2020 | 08:15 PM
BlownV8's Avatar
Had the same thing happen to mine. I had a walnut tree and sure enough it went right through the grill. You can get a replacement for not much money on ebay.
Old Nov 30, 2020 | 09:03 PM
BlownV8's Avatar
Left Side Hood Air Vent Grille Cover For Mercedes 2012-15 W166 GL ML Class GL350 | eBay
Old Dec 1, 2020 | 06:49 AM
Von Hayek's Avatar
GL450
Thanks. Just ordered.
Old Dec 1, 2020 | 06:50 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Those looks so much better in chrome.
