Cam Position Sensor Code
I yesterday picked up the truck from an oil change at my local indy shop, and around a minute after starting to drive away, the check engine light went on. I turned around and asked them to check the code (after confirming no leaks, oil fill cap on, dipstick in, etc). They called today and said it was a camshaft sensor position code (0340). I told them that they were relatively new, so they checked that the sensors were tight, wire connectors plugged in, reset the code, and took it for three separate test drives. No more code.
Drove 10 miles home without issue, but on second startup was idling roughly. Then was fine on drive.
I find this code a little coincidental immediately after an oil change. Any thoughts appreciated. Thanks.
Clean all 10 connectors with CRC contact cleaner. 4xcam sensor, 4xcam magnet and 2xECU
Another possibility is you have a wiring/connection issue with the sensors and their cables, and the wiring was "disturbed" during the oil change enough to set the code.
Have you unplugged the sensors and checked to make sure there isn't any residual oil from the original leak in the harness that has migrated back down to the connectors?
Back to the issue happening immediately after an oil change, could debris entering when refilling the oil possibly impact the sensor? it seems too coincidental to me.
Will monitor and report back.
