serpentine belt replacement
i cannot see how it can be done without removing the turbo charge pipe. i tried to remove the driver side turbo charge pipe. there is a bottom screw that needs to be removed but coudn't get either a short screw driver, it is a flat head, or a small socket, i think it is a 7mm. it is way too tight with no space. thought i'd ask the forum before removing coolant lines and other parts.
thanks
