Pre- Safe Function Limited / Traction Control Lights
Old Jun 23, 2023 | 12:00 PM
itwillbeslow's Avatar
2013 GL450
Last week I got a simultaneous "Presafe functions limited, see operators manual" and "Traction control currently unavailable" messages on the screen. TC, TC off, and BRAKE lights all illuminate on the screen.
Car goes into limp mode and cant accelerate well enough to drive safely. Issue is intermittent and comes on and off. Sometimes the issue will go away as soon as the car starts rolling first thing in the morning.
Dealer says it needs a traction control hydraulic unit ($3450). Did not say anything about sensors in bumper, etc.
I had an indy shop pull codes and there were several possible related CAN BUS codes:
1. u012100 [Current/History] Communication with ESP has a malfunction
2.1 C101500 [current/history] The values of component 'A7/3 (traction system hydraulic unit)' are faulty.
2.2 C232000 [stored] one or more signals sent from control unit 'N73 (electronic ignition lock control unit)' via the CAN bus are implausible
2.3 C232100 [stored] one or more signals sent from control unit 'N73 (electronic ignition lock control unit)' via the CAN bus are implausible
  1. C101500 [CURRENT/HISTORY]The values of component 'A7/3 (Traction system hydraulic unit' are faulty.
  2. C232000 [STORED]One or more signals sent from control unit 'N73 (Electronic ignition lock control unit)' via the
    CAN bus is implausible.
  3. C232100 [STORED]One or more signals sent from control unit 'N73 (Electronic ignition lock control unit via the
1 C180400 [STORED] Component 'A86/2b4(Left outer radar sensor, rear bumper) is disrupted by interference from An external transmitter
1 U041500 [CURRENT/HISTORY]Implausible data were received from control unit "ESP®". _
Do these codes line up with the dealer recommendation? It has traction control codes, but also bumper sensors.
Old Jun 23, 2023 | 12:03 PM
2013 GL450
Also forgot this one:
  1. C120400 [STORED]Control unit "COLLISION PREVENTION ASSIST" is disrupted by interference from an externe
    transmitter.
  2. C326600 [STORED]Chassis CAN busCAN signal "Operating condition" from control unit "Electronic stability
    program" is implausible.
  3. C32700 [STORED]Chassis CAN busCAN signal "Braking torque" from control unit "Electronic stability program
    implausible.
  4. C338700 [STORED]Chassis CAN bUsCAN signal "Brake request" from control unit "Electronic stabilty program"
    implausible.
  5. C371000 [STORED] system "collision prevention assist" has triggered a warning
  6. C371100 [STORED] system "BAS PRO" was triggered.
Old Jun 25, 2023 | 05:34 PM
2013 GL450
Anyone?? Help!
Old Jun 26, 2023 | 02:33 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
I would start with ESP module first, which is ABS pump with everything on it, seams like
Old Jun 26, 2023 | 08:20 PM
2013 GL450
Thanks, I am leaning toward this myself. This is the work the dealer quoted $3450 to do.
These units are all over ebay (used) in the $200-$300 range. Would you know if it would need to be programmed to the car after replacement?? If not I will probably DIY this.
I am dropping the car off for a more thorough troubleshoot at the indy dealer that pulled the CAN codes and will see if they have a similar recommendation.
https://www.ebay.com/itm/26629732194...3ABFBM1Oee1J5i
