Engine Rumbles After Highway Driving
Old Jan 21, 2024 | 01:50 PM
frogger42's Avatar
gl450
Lately, my 550 has been doing the weirdest thing after more than 30 minutes driving it freeway speeds. If I slow down the engine feels choked and it starts rumbling and then it flashes a check engine light if I turn my car off and wait 10 to 15 seconds and turn it back on the light goes away and the engine runs normally, below is the one of the codes that I see from the scan any ideas what this is?
Old Jan 22, 2024 | 06:47 PM
silvergl's Avatar
GL 450
I have no idea other than the code. But lugs and coils are cheap. You could even swap them with a other cylinder to see if the code moves too.
that's how I would start
Old Jan 22, 2024 | 09:07 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Guessing that a coil is getting heat soaked and starting to fail. Like silvergl says, swap the coil with another cylinder and see if the code moves with it.
Old Jan 24, 2024 | 09:20 AM
frogger42's Avatar
gl450
Thanks all while I’m there does it make sense to try to replace the spark plug or is that entirely independent?
I’ll report back with findings!
Old Jan 24, 2024 | 11:07 AM
silvergl's Avatar
GL 450
I would replace the plug and coil, probably about $100. in my opinion, if I am going to remove something i generally put in a new one.
Old Feb 17, 2024 | 06:29 PM
frogger42's Avatar
gl450
went ahead and replaced coil #2 and air filters, did the trick. Totally got rid of harsh idle, like new now!!!! I was also surprised at how relatively easy the replacement was. Still dont understand why all the wiring connectors are so darned frustrating to undo.
Old Feb 18, 2024 | 08:50 AM
chassis's Avatar
2017 GLE350 4MATIC
Next step is to replace the 7 other plugs and coils.
Old Feb 18, 2024 | 09:03 AM
L&N Caravan's Avatar
2003 E320 4matic wagon
which vendor was selected to supply coil and plug? Any other peripheral parts/pieces that would need replacing were process to be done again? Mine are coming up as well and need to prepare, thank you.
Old Feb 18, 2024 | 09:57 AM
frogger42's Avatar
gl450
rock auto. Went with Bosch coil and plug. Hengst filters. Need ratchet extension and universal joints.
also need 14mm plug socket and e8 star socket for coil screws. Also want some dielectric grease.
lisle 51410 pliers really help with coil pack removal.
Old Feb 18, 2024 | 10:10 AM
frogger42's Avatar
gl450
unfortunately our hood area is slightly less generous than the s class.
Old Feb 19, 2024 | 09:16 AM
Really good video showing what to expect
Thank you frogger42, on both counts!
