Engine drop without lift ?
I'll get one in at Spring, but I was just curious - has anyone ever lowered their engine / removed the subframe using those over-engine bars? I saw someone in the w212 AMG forum that looked like did and imagined it would be easier on an SUV. Although I think resting the frame on jack stands is way sketchier than a lift (even though I guess I have done that all the time.)
Look forward to your opinions.
The lift obviously gives more height.
I was thumbing through a wis procedure the other day and it showed the factory engine support frame being set up for the M276 engine. There were multiple bracing points. In comparison my bmw 3 series was fine with just the left and right legs resting on the fenders/ supporting a crossbar type engine lift and it used a single attachment point.
There could be other ways of doing the job safely so let's see what anyone else posts here, otherwise I'd follow the factory technique.
It just seems so much crap with this m278 is only reasonably done with the engine out that got the question asked. Plus my main mentor these days is Tasos and all his "check ups" start with complete engine removal lol
When I have time I will share the wis document I was looking at. It at least gives some clues as to where and how to support the engine even if one wouldn't be using a factory hoist rig.
I have a set of the quick jack lifts that are fantastic for working on my small sedan but unfortunately I not long enough to reach the jack points in the merc suv. They make a larger set that would work called the XL or something, and for the price I can't recommend a nicer product that folds up flat when not in use and is far more useful than jack stands for bigger jobs. Also offers better peace of mind to me when the vehicle is lifted above me for long periods of time.
That is the after-market cheaper equivalent. The Benz one is https://www.ebay.com/itm/254987430890
I've used both and the OEM one expired/hardened after 1 year but then again I kept it in a garage that got as low as 35 F in the winter
Valve covers have a rubber gasket (on the m113, not the m278) but most are sealed with that liquid. There is also a loctite 5900 that some people use.
