Slow Throttle Response
Anyone notice their GL63's throttle response is kinda slow. It is very obvious let say when you are slowing down making a turn then when you give it some gas again, there is that 1-2 seconds lags before the power would kick in
Brought it to the dealer, and the test driver did agreed with me but then he said that is how it designed to be, and there is no fix on it |
My car needs to be set to sport mode and the suspension set to AMG ++ for the best response.... If not ,mit can be sluggish.
What settings are you discussing? |
Turbo lag?
Originally Posted by Nihsel10
(Post 6186953)
Turbo lag?
Wrong settings....=dog |
Originally Posted by kuruma
(Post 6185856)
Brought it to the dealer, and the test driver did agreed with me but then he said that is how it designed to be, and there is no fix on it it is a technical issue with all M157 ENGINES . I own a 2014 ML63 that has the same problem . This is not a turbo lag , it is a slow response when pressing the gas paddle . As it is a slow communication between the paddle and engine . I tried turning my ECU to solve this issue . It helped but did not fix it completely . |
Do you know if they fixed it in 2015?
Originally Posted by Festertester
(Post 6404177)
See my thread https://mbworld.org/forums/w212-amg/...-mct-e63s.html Amg has to pull their head out of their arses and outsource the trans to zf |
Simple solution...RennTech.
Originally Posted by Trimmer2
(Post 6406133)
This is by design and is in line with the stately driving philosophy of The Mercedes driving experience. A manual downshift will almost eliminate the throttle tip in delay.
Originally Posted by alx
(Post 6420453)
(Post 6420460)
Actually it's due to the mechanics of the mct transmission and the time it takes to engage the wet clutch. But we can agree to disagree
Originally Posted by xxGenericSNxx
(Post 6407846)
According to the guys on the E board you still get the lag issue no matter what tune you get.
Mine is a 1994 s w140....I want to thank you because my mechanic said the same thing and believe it or not I'm grateful as I thought it was a trannie issue but it's not although it is a pain when slowing down,it seemed to start after I had a wiring harness installed.
Always wanted to try Sprint Booster to see if it helps in throttle response.
Anyone tried Sprint Booster at last? I am looking for the correct part# !!
