GLA Class (X156) Produced 2013-2020
How long for ECU to clear mods?
Old 03-21-2018, 01:47 AM
ddimatteo's Avatar
2017 GLA 250 4matic, 1993 Acura NSX
Question How long for ECU to clear mods?
I was wondering how long I need to wait after removing my pedal booster before the ECU clears and I can go to the dealer for service. Not sure if it's a time or mileage thing.
Old 03-21-2018, 05:59 PM
old guy's Avatar
'03 A4, '13 A5, '18 GLA-250
By pedal booster if you mean something like a Sprint Booster it doesn't alter anything in the ECU and would be undetectable as soon as you remove it.
Old 03-23-2018, 12:41 PM
ddimatteo's Avatar
How about if I used a Go Fast Bits Diverter valve or Dinan sport pigggyback
I'm assuming mods like
DINANTRONICS Sport Performance Tuner or the Go Fast Diverter need to be flush out of the ECU prior to servicing. Is there a easy way.?
Old 03-24-2018, 06:58 PM
old guy's Avatar
Any piggyback module like the Dinatronics Sport Performance Tuner simply changes the input from the boost pressure sensor by adding a resistance diode. It doesn't change anything in the ECU maps. Consequently it is totally undetectable as soon as it is removed. The Go Fast Diverter is simply a hardware change and also doesn't need any time to revert the ECU back since it doesn't change any ECU maps. Just be sure to remove it and put the OEM one back in before going to the dealer for service.
Quick Reply: How long for ECU to clear mods?
