Grinding noise when shifting into reverse.
When my 2016 GLA45 (37k ODO) is cold it's makes a grinding noise when it shifts into reverse. It sounds just like when someone who isn't used to driving a stick is having a hard time finding the right gear or they are just shifting wrong.
It's still under warranty and I'm going to bring it in, I was just wondering if anyone else ever had this issue? Thanks! |
The only noise I hear is the parking break disengaging when I forget to release it. My 2015 is coming close to 30k. I had the DCT transmission fluid change service this week and the dealer upgraded the software to correct a problem I'm having with the stop/start system.
Didn't fix the problem, but the transmission seems to shift lot smoother and quicker now. It will be interesting to know what they find with yours? I take it you had the rear Diff fluid changed at 20k and DCT fluid change at 30k? |
Cheers, I have this exact same problem on my '16.. Shifting into reverse when it's cold, it's got a grind - it only happens sometimes though.... What did you find out?? Did you solve it?
Bump// anybody else have this problem?
Originally Posted by col3man
(Post 7948329)
I should add one more thing...I've noticed that when the gearbox warms up above ~140F the problem seems to go away. So it may be a dif fluid viscosity issue. Either way, a source of frustration with this car
Interesting, when I was thinking about your reply this a.m., I came to the same conclusion, a change of the transmission fluid would probably help a great deal.. Maybe I'll do the differentials as well.. Any recommendations on fluids? I might run a lighter viscosity due to the cold winter here in Maine .. I'm a bit disappointed that there's not a large online resource about info for fixing these cars, I often work on my 993 and there's so much available information that it's overwhelming most of the time. But sort of the opposite with this car.. Thanks for your input!
(Post 7949222)
Interesting, . I'm a bit disappointed that there's not a large online resource about info for fixing these cars, I often work on my 993 and there's so much available information that it's overwhelming most of the time. But sort of the opposite with this car.. Thanks for your input!
tru that I came from the MS3/MS6 platform where the depth of collective knowledge is quite deep. this unicorn of fun is pretty much ignored. count the number of posts amongst the various merc models the x156 is a very forlorn creature some A45 bits may transfer, but, plan on being the guru, not the follower if you wanna "FUXWITIT" as nobody mods this car i'm still trying to figure out why I have a -73.5% STFT in bluedriver but my god its quick, and just so aggressively loud |
